Idle increases then stalls
Old Nov 11, 2004 | 05:51 PM
KLITSA's Avatar
KLITSA
My 94 F150 motor stalls after initial startup . First thing in the morning when I start up the motor goes into the normal fast idle , it will then increase in speed the check engine light will come on and then stall . I can restart the engine , is this an indication that the O2 sensor is malfunctioning . Ted
Old Nov 11, 2004 | 07:39 PM
5_labsownus's Avatar
5_labsownus
You need to check codes. Could be several things from a vacuum leak, fuel pump problem, TPS or ICS to name a few. The O2 sensor usually does not do this!
