97 5- speed tranny
Old May 18, 2002 | 10:06 AM
Ranger_4x2's Avatar
Ranger_4x2
97 5- speed tranny
I have a 97 four banger with a 5-speed. It makes a loud whinig noise at any and all speeds. Doesn't matter which gear its in although 4th is noticebly quiter. I checked the fluid which was about a half a quart low but didn't really help. It's gotten to the point where I can't even hear the radio on highway speeds. Any help would be appreciated.
Old May 21, 2002 | 01:02 PM
Ranger98's Avatar
Ranger98
97 5- speed tranny
hey....
I used to have a 94 Ranger, have a 98 now, but on my 94 I used to get a really high whinning noise too. I thought it was the tranny because it would only whine when I was in gear. Ended up being the rear U-joint. the pin bearings inside the U-joint were all crushed inside of the cap. The whining came from the spinning of the U-joint when I engaged the tranny, in gear, and would get noticibly quieter the higher the gear. guess this was because there isn't as much torque on the rear axle and drive shaft in higher gears at highway speeds.
maybe this will help, just sounded like the same probelm.
Old May 22, 2002 | 05:49 PM
Ranger_4x2's Avatar
Ranger_4x2
97 5- speed tranny
That sounds like it.When I push in the clutch the sound goes away.
Old May 22, 2002 | 07:47 PM
Ranger98's Avatar
Ranger98
97 5- speed tranny
yup, sounds like the same thing. it used to stop when I pushed the clutch in too.
Old May 22, 2002 | 08:26 PM
Flatbed392's Avatar
Flatbed392
97 5- speed tranny
