ford 9 " decoding
Old Nov 11, 2004 | 04:56 PM
sara_james's Avatar
sara_james
ford 9 " decoding
I have a ford 9 " with the following codes listed on the tag.
woh-t
3L50 8a8 311.
It is hard to tell if this is correct due to corrosion but as best I can tell it is. I need some help is this a 8-9 inch ford . I would appreciate the assistance and what is the proper width for the 54 f-100
Old Nov 11, 2004 | 05:07 PM
286merc's Avatar
286merc
Thats a nice one! It is a 3.50 ratio with the Limited Slip.
However the WOH doesnt compute. Look again & I can tell you right down to the original year and vehicle model.
Old Nov 11, 2004 | 05:15 PM
trav54's Avatar
trav54
If all of the third member nuts can be removed with a socket and extension it is an 8". If u have to use a boxed end wrench on the lower third member nuts it is a 9".
Old Nov 11, 2004 | 06:47 PM
mtflat's Avatar
mtflat
If it's a 9" the tag should read 3L50 9
I'd bet you have an 8"
Drum to drum measurement you want is 61 1/4" for stock width. An inch either way won't cause you any problems with reasonable tires.
Old Nov 11, 2004 | 08:08 PM
sara_james's Avatar
sara_james
The tag is hard to read but it might have been wdm-t cant really tell
Old Nov 11, 2004 | 09:32 PM
286merc's Avatar
286merc
WDM-T is correct it appears.
It was used in 63-78 F-100's and is listed as a 3.50 limited slip 9" with 28 spline axles. I have a few out back with that same code.
I believe that it is also the correct width for your 54.
Tim, that 8a8 is just a date code. Some tags will have 8 or 9 embossed to the far right of the axle code but it is not a given. Ive seen others marked right after the ratio such as 3.50 8 which is what the 8" under my old 26T coupe had.
Old Nov 12, 2004 | 01:35 AM
mtflat's Avatar
mtflat
Thanks for the info Carl. I stand corrected - 'bout the time I think I've got something figured out, Ford throws me a curve. On all the 9's I happen to have around here the size is marked right after the ratio.
