kickdown
Old Nov 11, 2004 | 12:25 PM
ford390gashog's Avatar
ford390gashog
kickdown
with the kickdown not attached do you have to manually shift into every gear or how does this work i have nver driven one with it unhooked i know for passing you drop into 2nd but do you have to up shift
Old Nov 11, 2004 | 12:33 PM
beartracks's Avatar
beartracks
With out a kick down it will upshift but it will do it very early.
Old Nov 11, 2004 | 04:14 PM
ivanribic's Avatar
ivanribic
No, with the kickdown not attached your truck will shift normally. You put it in drive and go. The ONLY thing a kickdown does is downshifts if you put the pedal to the floor. It has nothing to do with upshifting.
Old Nov 11, 2004 | 07:37 PM
MikeGV's Avatar
MikeGV
Kickdown
I just installed my kickdown on my C6/460 and it holds gears longer now if I'm in it.
