Tow Capacity
Old May 23, 2002 | 01:01 PM
FOX_MAZDA's Avatar
FOX_MAZDA
Tow Capacity
Does anyone know what the tow rating for a factory bumper hitch is on a 98 Mazda B3000 4X4?
Mike
Old May 24, 2002 | 07:16 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Tow Capacity
There is probably a stamped warning on your bumper that says do not exceed 200 pounds tongue weight or 2000 pounds trailer weight. This is the upper limit for the weak bumper attachment brackets. When in doubt always spend the $100 for a frame mounted hitch.
Old May 24, 2002 | 08:09 AM
FOX_MAZDA's Avatar
FOX_MAZDA
Tow Capacity
Thanks! Will probably do that.
Mike
Old May 28, 2002 | 07:22 PM
fast_eddy77's Avatar
fast_eddy77
Tow Capacity
just a note...make sure you check the actual tow rating for your vehicle - AS EQUIPPED! If you have a 3.0L (which I would believe is so, as your truck is a B3000), you are probably only rated for about 4500 pounds. I bought my ranger as a tow vehicle...sadly, I didn't do enough research and am stuck with a 3.0L, when I should have bought one with the 4.0L. Just a heads-up. I've seen too many accidents caused by too small of tow vehicle.
Old May 28, 2002 | 09:04 PM
94FordRanger's Avatar
94FordRanger
Tow Capacity
