Frame Swap
Old Nov 10, 2004 | 06:43 PM
74fordtruck's Avatar
74fordtruck
Frame Swap
alright. I have a F100 and there is a possibility of swapping my cab/motor onto a F250 frame/running gear. This F250 is in the woods and had a truck dropped onto the cab. As far as i'm aware, the motor should bolt up, assuming it's a FE. My question is, with the narrower frame of the 250, will the cab/front clip bolt up? THANKS
Old Nov 10, 2004 | 07:20 PM
dots's Avatar
dots
it should, the frame width under the cab should be the same. its only behind the cab that differs.
Old Nov 11, 2004 | 01:09 AM
whd507's Avatar
whd507
yes it all bolts right up.
Old Nov 11, 2004 | 02:00 AM
74fordtruck
I thought infront of the cab was different too.
Old Nov 11, 2004 | 12:16 PM
74fordtruck
oh, what about this. I have a pretty nice exhaust system bent up for my f100. i realize that being a shortbox the tails will need to be extended for a f250, but will the rest of the bends (particularly the headers and right from them) fit into an f250? thanks
Old Nov 14, 2004 | 11:51 PM
whd507's Avatar
whd507
yes it will fit. 2wd-2wd, 4x4-4x4
