coolant leak
Old Nov 10, 2004 | 06:13 PM
stroker"1"'s Avatar
stroker"1"
coolant leak
i have a '98 eb explorer w/ the 5.0. there is a slight coolant leak, but i can not see where it is coming form. it is just running down and steaming once it hits the exhust. not much is leaking, I fill the overflow when I change the oil, every 3500 miles. any ideas? can't see anything back there.
Old Nov 10, 2004 | 09:57 PM
1081's Avatar
1081
Can you tell if it is coming from front, back, top, by the firewall?
Old Nov 11, 2004 | 02:20 PM
stroker"1"'s Avatar
stroker"1"
it coming from somewhere near the firewall because it is going straight down on the exhaust when engine is running. There is no puddles in the driveway.
Old Nov 11, 2004 | 04:32 PM
CobraXP's Avatar
CobraXP
I would look at either a blown intake gasket - you should be able to tell if that is it - or look at the heater core hoses and see if they are leaking somewhere in the back.
Old Nov 11, 2004 | 08:29 PM
1081's Avatar
1081
I agree, that is what I was going to guess.
Old Mar 19, 2007 | 11:36 PM
missviv2's Avatar
missviv2
Can you post what the problem actually was, please? I have a leak at the back of the engine that I can't find the source. Thanks!
Old Mar 20, 2007 | 08:27 AM
taz1y's Avatar
taz1y
also could be your frost plug leaking
Old Mar 20, 2007 | 08:49 AM
1081's Avatar
1081
Not to be confused with a "freeze" plug.
Old Mar 20, 2007 | 10:51 AM
quicklook2's Avatar
quicklook2
go to a radiator shop and have them do a pressure test.
could be the heater core or hoses.
Old Mar 21, 2007 | 07:39 PM
missviv2's Avatar
missviv2
Thanks all! It's in the shop as we speak getting new freeze plugs.
Old Mar 21, 2007 | 11:15 PM
AuRevoir's Avatar
AuRevoir
My 1999 Limited has a coolant leak, not hitting the exhaust manifold, just a small puddle. it seems to be from the drivers side but I cant see where its coming from. Maybe I'll jack it up and take a good look.
Old Mar 21, 2007 | 11:25 PM
missviv2's Avatar
missviv2
My leak didn't hit the manifold either. My small puddle was on the passenger side. The shop did a pressure test on the system and found the source quickly. I wasn't able to see the source when I went searching for it. They are having to drop the tranny to get to them and replace.
