Cruise Control-Failed and I need check out procedure!
1990 F-150 4.9L w/E40D transmission.
Cruise control has failed.
Does anybody have a step by step diagnostic procedure to evaluate this system?
I have the Ford two volume shop manual but is not very helpful, well at least not to me!
Are there any fairly detailed step by step procedures for checking the various control pieces out in this system?
Any advise and or guidance would be greatly appreciated.
Thanks.
DaveP Kywoodwrkr
(Name says it all-maybe I shouldn't be working with electrical/mechanical things!)
Thanks.
DaveP Kywoodwrkr
if none of the above work, take the cruise sontrol buttons out of the back of the steering wheel and clenn the contacts, and check the cruise control servo/computer wich is located by the master cylinder on the fender and take the top off of it and check to make sure that the plastic gears inside are not all stripped out.
http://www.dalidesign.com/hbook/ccmain.html
here is a site I used to troubleshoot my cruise control
hope this helps!!
hope this helps!!
Cruise Control
Ladyfire,
e-mail address is
david.petersen@eds.com
I tried the PM thingy but I haven't enabled it on my profile so can't send either.
Besides woodworking, I've been in computers since 1962 but you sure couldn't prove it! :-|
Thanks.
DaveP
e-mail address is
Thanks.
DaveP
