question about trannys?
Old Nov 10, 2004 | 10:25 AM
airmanfallon's Avatar
airmanfallon
Hey guys I had a qestion I had never messed with Auto's before I allways had 5 speeds....I am building a 408 W right now I have the World Class T-5 5 speed from Jegs it will not hold up to this motor so I have bought a JW bell housing for a TH400 tranny to a SBF...now I am confused what you have to do to make a TH 400 fit in my 408? Input shaft? I have seen people do it alot.....but I know little about Auto trannys..also would i have to change the output shat as well? and yoke? Thanks Airman Fallon
Old Nov 10, 2004 | 10:56 AM
85e150's Avatar
85e150
Didn't the JW boys give you the story on how-to? Or is it used? Well, here, go ask them:
http://www.racewithjw.com/
Old Nov 10, 2004 | 11:07 AM
airmanfallon
wow I never could find there website.......appericate it still can't find anythng but I will call them today...thanks..airman fallon
Old Nov 10, 2004 | 02:45 PM
Mike G's Avatar
Mike G
Originally Posted by airmanfallon
... the World Class T-5 5 speed from Jegs it will not hold up to this motor .....but I know little about Auto trannys..
Swap it out for a Tremac...
--Mike
Old Nov 10, 2004 | 10:18 PM
Matts72's Avatar
Matts72
I don't think even the mighty tremec could handle that... you can build them to take a 1000 HP, but its not really worth it, since only extreme racing clutches could handle it.
Old Nov 11, 2004 | 10:35 AM
airmanfallon
Yeah I agree I had a Tremec world class T-5 it was really expensive and allmost coulden't handle my weak 331 stroker(406 HP) I had in it before...It started to grind gears in first and stuff....but I called JW I guess you do not need to change anything but you need a crank sapcer and a JW flywheel and a GM tourqe converter...and hack saw off teh bell houseing...so this should be a intersting adventure thanks for the help guys.....I just hope I can find a TH 400 that can hold this motor it should be about 700 on NOS..If you know anyone who can a build good TH 400 for cheap let me know I am just a Poor Airman in the USAF lol Thanks again Airman Fallon
Old Nov 11, 2004 | 10:41 AM
Mike G's Avatar
Mike G
Any particular reason you shyed away from a nice stout C6? One way to look at the handling capabilities, you should already be rolling and in a higher gear when the 700hp demands kick in. If you are hitting the trans with 400hp out of the line, you should be in fine shape.
--Mike
