Sponsored by: Real Truck
key pad programing
Old Nov 9, 2004 | 08:47 PM
Mr truck's Avatar
Mr truck
key pad programing
hi guys.my 2003 f 250 came with factory keyless entry but i put a aftermarket alarm system, my wife`s truck has another aftermarket alarm system but the key pads are all messed up,i was wondering if i could program the original key pads from my `03 f250 lariat to work on my wife`s truck,and how to do it,i can`t find my owner`s manual for the `03 f250,if i am not mistaking there is something about programing this things in the manual somewhere.thank you for your replay in advance.
Old Nov 9, 2004 | 09:29 PM
1956MarkII's Avatar
1956MarkII
If you know the truck's master code, just enter that, then hit the 1-2 button. Now enter the code you want to add (from the other truck), and if it takes the doors will lock, then unlock. That tells you that it accepted the code.
Old Nov 10, 2004 | 11:25 AM
PaulC's Avatar
PaulC
Just an FYI: That action will create a second usable code for the keypad. It won't replace the original factory code.
