High pressure Oil pump?
Old Nov 9, 2004 | 05:42 PM
sb711's Avatar
sb711
wondering if anyone has replaced H.p. oil pump? found big leak in driveway, inspected and found oil pooled on intake manifold,i wastold it was oil pump which drives fuel injection system. pump wasnt cheap, any input is appreciated.
Old Nov 9, 2004 | 05:45 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Probably not the pump itself. It's more likely that it's one of the high pressure lines from the pump to the head.
Old Nov 9, 2004 | 05:50 PM
barebackjake's Avatar
barebackjake
i second that, i doubt its the pump, i would check lines and turbo pedistal first. what year and how many miles??
Old Nov 9, 2004 | 06:56 PM
sb711's Avatar
sb711
99model w/110,000 miles, I hope it is ,cause mech. is replacing today. wish ihad taken a little more time to research (just found this forum today)
Old Nov 9, 2004 | 07:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
That's a major bummer if you are out of pocket for the pump.......I hope your mechanic is not one of the few thieves that give all mechanics a bad name.
