What bolt pattern does the 300 i6 have.
Old Nov 8, 2004 | 10:52 PM
blue66tang95f150's Avatar
blue66tang95f150
Does the 300 have the windsor 289/302/351 style bolt pattern for the trans.
Just thinking of some motor swaps.
Old Nov 8, 2004 | 10:53 PM
frederic's Avatar
frederic
Yes, it does.
Old Nov 8, 2004 | 11:13 PM
stangdano's Avatar
stangdano
The better question is does the ZF have the same bolt pattern as the M5OD?
Old Nov 9, 2004 | 12:19 AM
andym's Avatar
andym
If you get a ZF that was behind a 300 or 351w, yes.
Old Nov 9, 2004 | 11:04 PM
stangdano's Avatar
stangdano
Are there 2 different models of the ZF?
Old Nov 10, 2004 | 01:00 AM
andym's Avatar
andym
No, there are more. The big block diesel pattern has different ratios. And there are 420 lb-ft versions and 470 lb-ft versions.
Old Nov 10, 2004 | 06:49 AM
frederic's Avatar
frederic
ZF Diesel 4-sp (SF-42)
ZF SBF 5-sp (S5-42)
ZF BBF 5-sp (S5-42)
ZF BBF 5-sp (S5-47)
ZF Diesel 5-sp (S5-47)
The above are for 96 and earlier zf shifted trucks. The newer trucks changed the bell housings with the Triton engine series and the powerstroke. So, the transmissions changed as well. Also, Ford added a 6-sp ZF.
Which BTW, if you were to take a 6-sp powerstroke ZF and put it against the back of a 460/429 block, its darn close... I've been having these evil voices....
Old Nov 12, 2004 | 10:11 PM
stangdano's Avatar
stangdano
Sounds like a cool conversion. Let me know if you ever attempt it. That's the only thing that makes me lean towards getting a newer powerstoke with the 6 speed instead of getting my favorite body style (92-97). BTW, I would have to imagine that a newer 6 speed would bolt up to an older powerstoke... Is that a good assumption?
