Code Interpretation
Old Nov 8, 2004 | 10:10 PM
hopperbb's Avatar
hopperbb
Question Code Interpretation
what does a po603 code mean?
Old Nov 8, 2004 | 11:55 PM
SBV45's Avatar
SBV45
P0603 Powertrain Control Module Keep Alive Memory (KAM) Error
The PCM stores information in Keep Alive RAM (a memory integrated circuit chip) about vehicle operating conditions, and then uses this information to compensate for component variability. Keep Alive RAM remains powered when the vehicle key is off so that this information is not lost.
You can get this error if the battery has been disconnected for more than 5 minutes.
How did you detect the error?
Old Nov 9, 2004 | 06:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
Enjoy FTE
