Help with casting numbers
Old Nov 8, 2004 | 09:14 PM
96ExtracabPSD's Avatar
96ExtracabPSD
I have come across a bunch of engines on a property clean up job. There are 3 Ford engines and two of them I was able to figure out as 351 from this site. The third engine I can't find. I think it must be a 385 series. I'm pretty sure that I didn't find the block casting number now.
What I have is
Block, these munbers were down on the side of the block. V, E, 1 or I,
19DIF
And the suffix code I imagine because it was stamped on a
machined surface on the side of the block. 8 D 305
Heads are C8AE-H
Intake is C8AE 425-F
I can look again tomarrow at the block for the casting number by where the starter bolts and check the crank for the 2U or 4U. Yes, I have been searching.
So is it scrap metal, or is it any good for a street engine for my 58?
Thanks for any info.
Old Nov 10, 2004 | 11:50 AM
airharley's Avatar
airharley
Sounds like you do have a 68 385 series engine. Just need the crack code to know which one. Most likey it will be a 429.
Old Nov 10, 2004 | 03:22 PM
greenhighboy's Avatar
greenhighboy
The head casting numbers are for a FE motor. You can go here for a more info.
http://www.network54.com/Forum/threa...eid=1100040966
Old Nov 10, 2004 | 08:00 PM
96ExtracabPSD
Thanks, and yes, it is an FE moter. Did a bunch more searching last night and found that out today at work. Appreciate the help.
