What to look for???
Old Nov 8, 2004 | 05:25 PM
fast freddie's Avatar
fast freddie
What to look for???
Can anyone tell me what kind of things to look for that might cause the ABS light to stay on? I was on the return leg of a 500 mile trip and I just happened to notice that the light was on. No other symptoms. I don't really know what the light is telling me. The only clue that I have is that right after I got home I noticed that I had a small leak in the heater core. When I removed the glove box to replace the heater core, I noticed that there is a module of some kind mounted right next to the heater core. It says something on it about "For use with dual rear wheels only". I think it might have something to do with the ABS??? Maybe the steam from the heater core got to the module?? 1995 PSD CC
Old Nov 8, 2004 | 05:53 PM
realhp's Avatar
realhp
Do you have access to a scan tool that can pull the ABS codes?
Old Nov 8, 2004 | 05:57 PM
fast freddie
No, not unless I go to one of the local Auto Zone stores and I really don't have a lot of confidence in those folks.
Old Nov 8, 2004 | 06:04 PM
realhp's Avatar
realhp
I agree with you on not having confidence with them but if you could at least get the code # I could look it up on my factory manual and guide you in the right direction. Really with out knowing the code it could be a lot of things causing the light to be on.
Old Nov 8, 2004 | 06:24 PM
fast freddie
I'll see what I can do. Thanks for the help!
