I recently had my gauge face changed to a white background. Ever since the change, I have noticed that my speedometer is reading 10 mph over what I am actually going. It also hesitates -- after I get up to about 10 mph it will finally move and then jumps up to 20 mph. It's not a huge problem, but a nuissance that I would like to get rid of. Has anyone else had this problem and is the fix easy?
I really don't know for sure, but did you disconnect the speedo cable when you were replacing the gauge faces? Sounds like you may of just hooked it back up a little off.
I would say that the hesitation may be caused by a rubbing of the face aganist the needle.
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Enjoy FTE
