fuel pumps
Old Nov 8, 2004 | 03:00 PM
kenny150's Avatar
kenny150
fuel pumps
I have a 1992 F150 with the 5.8 and the auto tranny and dual tanks. Say, if the front tank runs dry, will the rear tank kick in and take over?
Old Nov 8, 2004 | 03:04 PM
gatesj's Avatar
gatesj
If you switch them it will, but it won't switch automatically.
Old Nov 8, 2004 | 08:46 PM
kenny150's Avatar
kenny150
are you sure? I had a full rear tank, then ran really low on the front tank and my rear tank is down to 1/2
Old Nov 10, 2004 | 03:19 PM
gatesj's Avatar
gatesj
Absolutely positive. There IS a common problem with running from one tank and having it not only pump to the engine but to the other tank, but in this case your rear would have gone up instead of down. Maybe you have a wiring problem so both pumps are running or something. Really strange.
Old Nov 10, 2004 | 05:47 PM
mike L's Avatar
mike L
Cross Tank Fuel Flow recall 93S68
Check for recall should still be good ( 12 years, milage ?). Your rear tank is going to your front tank. Check out alldata.com for recall 93S68 http://www.alldata.com/TSB/20/92201602.html Call Ford service department with your vin number. Also tell them whats it is doing. I think they will add a check valve and a new fuel pressure regulator. Do a advance search above for Cross Tank fuel flow. On my 87 my fuel selector valve went bad and did the same thing, they changed the setup in 1990 though. Carfull your front tank can leak out and also build up pressure. Try a Google search for Ford Recall 93S68 for more info.
