Glow plug operation
Old Nov 8, 2004 | 11:48 AM
toddjlyons's Avatar
toddjlyons
Glow plug operation
I'm still having hard starting problems. New glow plugs, relay and still when the temp drops below 45 I have trouble. Here is theory I'll run by everone here. After trying to start it a couple times I'll here the glow plug relay finally click and it will start. Could it be my oil temp sender or something related to cranking a cold engine and circulating cold oil? Where is this temp probe? Todd
Old Nov 8, 2004 | 01:12 PM
sundy58's Avatar
sundy58
I think there are three sensors that control your glow plugs. Engine oil temp, Intake air temp and Barometric Pressure. The intake air temp if open will default to 15 F I think. Look at your ammmeter when you turn your key to the on positon it should pull way down the after about two minutes return to the N on the normal. I do that cycle twice on a 50 F or below day if I didn't plug my truck in.
Old Nov 8, 2004 | 04:00 PM
toddjlyons's Avatar
toddjlyons
What I am seeing is the ammeter dropping just slightly below the 'N' and then after cranking a couple times and waiting for 20 seconds or so I see it pull way down and hear the gpr click. It will then start since the plugs have now been heated. Todd
Old Nov 9, 2004 | 06:00 AM
sundy58's Avatar
sundy58
That seems strange. Can you get the codes off your truck? That could tell you if a sensor is bad. Or not! It depends. Do you have a multimeter? I will take some measurements on my truck so you can compare if you can do the same.
Old Nov 9, 2004 | 03:08 PM
toddjlyons's Avatar
toddjlyons
Thanks sundy58!
Old Nov 12, 2004 | 04:26 PM
toddjlyons's Avatar
toddjlyons
I"M CURED!!!!! Stupid me, I've been fighting this for eight months! When I changed out my glow plugs I also changed my gprelay. Well guess what, the replacement was bad! I bench tested it and it sticks. About every third to fourth time I tested it it would work. Fortunately, I saved the old one because I'm an old scrounge. I stuck it in and cycled it. The ammeter pulled down instantly to where it should. I locked up and went inside for the night. My wife was skeptical about not plugging my truck in but I had faith!
10 hours and 18 degrees later she started right up! Thanks everyone for your support and ideas! Todd
