Throttle bodies
Old Nov 8, 2004 | 11:23 AM
clark714x4's Avatar
clark714x4
Talking Throttle bodies
I found a little water leak on the bottom coolet line on the throttle body. I was going to weld it but was wondering if anyone has replace their double throttle body with a 60mm single throttle body from a mustang and if they got any better performance from it??? I have a K&N filter system for a 60mm throttle body and would like to use it.
91 F150 4x4 5.0l xlt
Old Nov 8, 2004 | 03:29 PM
EPNCSU2006's Avatar
EPNCSU2006
How are you going to adapt the mustang throttle body to the truck intake?
Old Nov 8, 2004 | 04:48 PM
clark714x4's Avatar
clark714x4
That's what I'm asking. Are the upper manifolds/plenums swapable???
Old Nov 8, 2004 | 09:03 PM
EPNCSU2006's Avatar
EPNCSU2006
You would have to swap the whole manifold - upper and lower. You would also have to modify the throttle linkage to work with the mustang throttle body and intake from what I understand. It's certainly possible, although I can't say what you would gain from the swap.
