Wanted:tips on how spare tire installed under
Old 11-07-2004, 04:15 PM
snipa's Avatar
snipa
snipa is offline
I Know this may be obvious to you all, BUt I'm having a heck of a time trying to figure out this tire gets mounted under my 53
I have the spare tire bracket and 1, 7" long bolt With a "u" with holes through the "u", and 1 nut for the bolt--- and thats it.....
I always driven with the spare in the bed, But know I finally want it under the truck.
Whey does the u bolt for the tire bolt have 2 holes near the end of the "u"
MAybe a picture would help me to figure how this all mounts up
Todd
Old 11-07-2004, 05:52 PM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
I'm not sure if the '53 is the same as '52. My '52 has two bolts that hold the spare tire to the bottom of the frame. The bolts are in two pieces. The small eye-bolt, bolts to the bottom of the frame and the longer u-bolt connects to the eye-bolt with a clevis pin. The nut on the longer u-bolt holds the carrier up. I just added a photo to my gallery of the bolts (the threads are covered in masking tape). Hope this helps a little. ...Terry
Old 11-07-2004, 07:53 PM
snipa's Avatar
snipa
snipa is offline
Wow! thanks Terry! that looks like the same parts from my 53
thanks so much for the helpful picture and info
I do have the small eyebolt is on the frame on the back of the frame drivers side
the tire holder frame the a notch cut in it on one side only ---i assume to slide into the eyebolt there..
there is a hole drilled in the other side of the tire holder....but where does this connect on the frame???
this is where i get lost
Todd
ps-a GREAT looking truck you have
Old 11-08-2004, 11:14 AM
AXracer's Avatar
AXracer
AXracer is offline
Anyone know where and how the spare was mounted on a 56 Panel?
Old 11-08-2004, 01:47 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
The eye bolt should be fixed on the pass side about 24" in from the rear bumper. The "J" bolt attaches upside down in the last hole in the frame on the drivers side. The two holes in the "J" bolt arefor a cotter pin to prevent it from bouncing out of the frame.
I have one installed on my 56 and if needed I will take photos. Also the panel trucks mount the same way.
Kevin Bigwin
Old 11-08-2004, 01:49 PM
snipa's Avatar
snipa
snipa is offline
thanks Kevin
Could you post a pic please?
I dont have the cotter pin
-could I use a bolt and screws instead through the u bolt
Old 11-08-2004, 02:01 PM
bigwin56f100
I will have to email it to you as for some reason I cannot post attachments.
Kevin Bigwin
I will do this now and maybe you can post it for others?
Old 11-08-2004, 02:03 PM
snipa's Avatar
snipa
snipa is offline
ok i"ll give it a try thanks!
Old 11-08-2004, 02:14 PM
AXracer's Avatar
AXracer
AXracer is offline
I'd like to see the pix too, either email or online, thanx!
Will that system still work with a trailer hitch installed?
Old 11-08-2004, 02:24 PM
bigwin56f100
Todd check your email
Kevin
Old 11-08-2004, 02:46 PM
bigwin56f100
Well? any help? need more pics? AX racer email me and I will send them tio youtoo.
Kevin
Old 11-09-2004, 11:48 AM
bigwin56f100
I dont mind helping but a little gratitude (sp)? goes a long way!
Kevin Bigwin
Old 11-09-2004, 12:57 PM
AXracer's Avatar
AXracer
AXracer is offline
A BIG thanx! Looks very similar to current pickup system, so I don't think I'll have too many problems finding the parts. I knew there must be a place for it other than bouncing around in the back of the panel. Now to solve the two different bolt pattern dilemma...
Old 11-09-2004, 11:06 PM
Overkill-F1
Snipa/Todd, I've put a photo in my gallery of the eye-bolt/u-bolt together as you requested. There is one of these bolts at each end of the spare tire carrier. You can use a bolt instead of a clevis pin if you can't find one, just leave a little play between the u-bolt and the eye-bolt. ...Terry
Old 11-10-2004, 08:09 AM
snipa's Avatar
snipa
snipa is offline
Thanks for the info Terry! Your help is very appreciated. the photos were great.
I 'll try to track down another origianl bolt like that
Todd
Quick Reply: Wanted:tips on how spare tire installed under
