Sponsored by: Kumho
ball joint help, again!
Old Nov 7, 2004 | 04:13 PM
waldreps's Avatar
waldreps
Can anyone tell me how to tighten down the ball joint nuts without the ball joint bolt turning with it? I am using moog ball joints. I am trying to tighten the lower one. I'm just basically getting the nut started and after a few revolutions, the whole assembly is turning instead of just the nut. Now it won't come off or go on any further. Also, where can I get a puller to pull the spindle bearing out? I bought one from Harbor Freight but it doesn't work with my spindle. The little tabs on the fingers don't stick out far enough to get under the bearing. Thanks.
Old Nov 7, 2004 | 06:13 PM
waldreps's Avatar
waldreps
I got the lower ball joint nut tight by lifting up on the spindle to create pressure to keep the ball from turning. But, I still need to know what puller to use to get the spindle bearing out of the spindle. Again, the one from Harbor Freight doesn't work. Any suggestions?
Old Nov 8, 2004 | 08:28 PM
bigsbetter's Avatar
bigsbetter
whats the vehicle aplication?
Old Nov 9, 2004 | 11:31 AM
waldreps's Avatar
waldreps
Thanks, but I got it. It was for a 1994 F150 4x4. I had to modify the Harbor Freight puller to make it work.
