Aerostar Ford Aerostar
Oxygen O2 Sensor Replacement
Old Nov 7, 2004 | 02:06 PM
vintageant's Avatar
vintageant
Looked in this forum for a "how to" replace the O2 sensor, without success. So I figured it out for myself and post this for others.
First buy the sensor. The 4.0L takes a Bosch #15718. It cost me $49.98 plus tax at Discount Auto. The 3.0L may be different
Best time to do this is during an oil change when the oil filter is removed. It gives you more room to work. You'll see the sensor screwed into the exhaust pipe just below/behind the oil filter.
Remove the inside engine cover, and unclip the connector on the right, passenger side. You may have to remove the retaining clip to do this. I had to.
Pull down the wire from underneath. Use a 7/8" or 22mm box wrench fed over the connector wire, and lots of muscle to undo the sensor. Replace the sensor and feed the connector wire up to where the old one came from. You'll need to have an assistant inside to pull the connector up.
Other posts indicate these should be replaced every 60,000 miles. This is the first one I've replaced on our Aerostar and it now has 146K. Our Average MPG around town is 12.5. Let's see if this helps.
John
'93 Aerostar 4.0L 146K
Old Jul 11, 2009 | 02:59 PM
93nighthawk's Avatar
93nighthawk
I know I am raising the dead, but this is the only post that I found that described how to get to the wire connection. I just got out from under my Aero with a confused and pissed look. The rear O2 connector is easily gotten to, the front one just disapears into the heart of the Aero.
Old Jul 11, 2009 | 04:29 PM
vintageant's Avatar
vintageant
Ha! Glad it helped! The Aero went in early 06, replaced by a Toyota Highlander. Apart from oil changes, tires and brakes, we've not had to do anything to it! But it's only 7 years, 85k miles old.
Old Jul 11, 2009 | 09:54 PM
93nighthawk
Thank you so much vintageant!
You saved me hours of aggravation trying to find that connector. And you were right, once I got the doghouse off it was right there on the passenger side. It is a tight fit, but once you disconect the connector from the mounting point, it is easy to disconect. Now plugging it back in is another story. You really do need a helper to get that cord up there and pluged back in.
Again thanks for your post vintageant! You are always welcome here, even if you don't own an Aero anymore.
asavage
Aerostar
Jun 17, 2021 01:59 PM
KhanTyranitar
Aerostar
Feb 4, 2011 04:03 PM
therealulysses
Jun 27, 2010 02:17 PM
Dracoscott
Aerostar
37
Sep 20, 2005 03:07 PM
csh102
Modular V8 (4.6L, 5.4L)
Aug 14, 2004 02:08 PM
