Radio Options
Old Nov 7, 2004 | 01:34 PM
zuikoman's Avatar
zuikoman
Radio Options
I got a 75 f-250 with an inop Dodge AM radio in it. I would like to replace it with a Ford OEM AM/FM. Can I take a 2 shaft radio out of just about any Ford car/truck from the 70s or early 80s?
The Dodge I got is quite a bit too wide so the guy who put it in didn't use the face plate with it. It took some doing to get it in or out of the hole.
Thanks.
Old Nov 7, 2004 | 02:07 PM
prcrboy's Avatar
prcrboy
Yes, should work ok. May require a little wiring since yours has been changed once.
Old Nov 7, 2004 | 07:24 PM
ford390gashog's Avatar
ford390gashog
any thing from 73 to 79 ford trucks work
Old Nov 7, 2004 | 08:40 PM
Mil1ion's Avatar
Mil1ion
No,
The cars have an different length shafts on the front for mounting.
They are offset....
the truck needs the straight across face plate.
_|_ -|-
Keep looking
Old Nov 8, 2004 | 10:50 AM
zuikoman's Avatar
zuikoman
Thanks for the tip. Looks like you are right on the **** positon. Unfortunately that will make it a lot harder to find. Not sure how common FM was in those trucks.
I suppose I might be able to modify the bracket to make one work if I found one in a car.
Old Jan 18, 2005 | 08:28 PM
treefrog75's Avatar
treefrog75
Options for radio
I know you want OEM, so check out ebay. Also, if you want a new one to fit, check out Crutchfield.com. They have at least 1, a Sanyo cassette-radio that fits.
Old Jan 18, 2005 | 10:52 PM
Mil1ion's Avatar
Mil1ion
I have tried numerous times to make it fit.
It can't be done (by me anyway) because you have to use spacers to make the mount the same on both shafts but when you do this you lose the threaded shaft to attach to.
I would go aftermarket.
Pioneer still makes a 2 **** AM/FM Cassette
Old Jan 18, 2005 | 10:59 PM
FordPickup460's Avatar
FordPickup460
Why not just go CD player ?
Old Jan 19, 2005 | 12:15 AM
!977f250's Avatar
!977f250
Custom Auto Sound makes a number of radios that fit the original bezel and accomodate two shafts.
Old Jan 19, 2005 | 11:15 AM
73Custom's Avatar
73Custom
Several companies even make a stock appearing shaft style radio that controls a cd changer...
But I just went with a normal pioneer cd player. Sounds much better than the old one, but did require some cutting of the dash. If it's done carefully, it will still look good.
Marty
