any ideas?
Old Nov 7, 2004 | 08:13 AM
tampabandit's Avatar
tampabandit
any ideas?
ok guys i have a 91 f-150 ext cab and the fuel pump in the front tank runs constantly but it is now sounding like it is starving for gas..it wont start without a spray of starting fluid in the throttle body and it will idle but as soon as i hit the gas it stutters...if i try to restart the truck it wont unless i hit it again with the starting fluid. i have dropped the tank and it seemed to be pumping fuel thru the filter and it has pressure at what looks like a valve stem on the fuel rail and i have replaced the what i believe is the fuel pressure regulator any ideas on this would be grateful im starting to lose faith in ford..thanx for any help tim
Old Nov 7, 2004 | 10:29 AM
LxMan1's Avatar
LxMan1
You need to check the actual fuel pressure with a gauge. It sounds like it is weak or is somehow pumping gas into the rear tank.
