window crank trouble
Old Nov 6, 2004 | 07:40 PM
Raymond64's Avatar
Raymond64
I just installed new replacement window seals in my 1979 F350 SC 4x4 and i am having problems rolling up the window, it will go up, but in short burst from the window crank. window goes down smooth. Any help or suggestions... also looking for some custom ideas or pictures for replacement of my door panels since they came off not so smooth.. Ray
Old Nov 6, 2004 | 09:20 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
Does it feel like it is slipping when going up? If so, the regulator is probably worn out.
Old Nov 7, 2004 | 08:02 AM
slimone's Avatar
slimone
Windows
Hi, I have a 74 f250 that when I first got it 16years ago ,had the same problem with the windows going up eazy, pulled of the panel and found all the lube on the reg,had dried up ,cleaned them and the track with a degreaser and put fresh grease on them and have been doing so every two years (live in Az lot of dust) but they work like new after that, give that a try helped mine. good luck Slim
Old Nov 7, 2004 | 09:28 AM
Raymond64's Avatar
Raymond64
does not slip when going up but it feels as if some thing gets caught in the gear when going up . a visual looks as if all the teath are lining up ok and all the teeth are in tact. thanks .ray
Old Nov 7, 2004 | 09:31 AM
Raymond64's Avatar
Raymond64
Thanks slim i will try that since this truck did come out of arizona
