tfi
Old Nov 6, 2004 | 06:35 PM
notsoswwuyd's Avatar
notsoswwuyd
tfi
Any one know what years ford use the tfi disturbutor. Also what years were the 351w "roller". Also anyone know the specks on a roller 351w.
thanks all for your time.
Old Nov 7, 2004 | 07:21 AM
jwtaylor's Avatar
jwtaylor
Used the tfi distributor on efi engines.
The 351w went roller compatible in 93 1/2, you would see F4TE stamped on the block as part of the casting number. These engines still used flat tappet camshafts.
The only F4TE 351w engines I know of that came from the factory with an actual roller camshaft, were the 97 f-250's.
The first generation lightnings had F4TE blocks but flat tappet camshafts as well.
