Modular V10 (6.8l)
head bolt torque specs and pattern.. HELP!!
Old Nov 6, 2004 | 02:02 PM
V10plugster's Avatar
V10plugster
Hello from Phoenix AZ. I had a plug blow-out of my 1999 F250 and had the head helicoiled. Does anyone have information on how to properly torque the head bolts and what pattern?
Old Nov 6, 2004 | 05:16 PM
Smokin_Superduty's Avatar
Smokin_Superduty
V10plugster, Welcome to FTE! A great place for valuable information.
My Haynes manual gives detailed sequence for the cylinder head, I hope that I can explainit well enough. First of all, new head bolts are to be installed, as these bolts are torqed to yield, meaning that the old ones are too stretched to be effective. The diagram shows 12 head bolts, 2 rows(top and bottom) of 6. I will list the torque sequence for the left cylinder bank, the right cylinder will be a mirror image.
#1 - bottom row, 4th from left
#2 - top row, 4th from left
#3 - bottom row, 3rd from left
#4 - top row, 3rd from left
#5 - bottom row, 5th from left
#6 - top row, 5th from left
#7 - bottom row, 2nd from left
#8 - top row, 2nd from left
#9 - bottom row, 6th from left
#10- top row, 6th from left
#11 - bottom row, 1st from left
#12 - top row, 1st from left
First time around the sequence torque all bolts to 30 ft./lbs.
Second time around, using a torque angle indicator, tighten bolts 90 degrees.
Third time around, tighten all bolts another 90 degrees.
I hope this helps, good luck!
Old Nov 12, 2004 | 12:03 AM
V10plugster
thanks a million Smokin_Superduty!
Austy
Sep 2, 2013 01:04 PM
Super Steve
Arizona Chapter
Jun 12, 2013 07:18 PM
fluidp
Jun 28, 2008 02:56 PM
Mr Man
Arizona Chapter
Sep 7, 2004 07:41 PM
dinosaurfan
Aug 21, 2002 08:33 PM
