Tow command important for resale?
Old Nov 5, 2004 | 10:02 PM
tpetty's Avatar
tpetty
I'm strongly considering ordering a new F250 to use as a commuter, and occasional bed hauling (landscaping, firewood, etc.) I'm leaning toward the 6.0 simply because it gets better mileage and most of the extra cost is kept at resale - I don't think you really need to drive 200000 miles to recoup the cost because the truck is worth significantly more at resale. (Although I'm not deadset against the gasser.)
Anyway, I don't have any need for towing a big trailer, and so don't really need the trailer braking system. However, since it's not really an expensive option, is this something I should get just for eventual resale? Do you think that this is going to be something that becomes standard and expected?
Old Nov 6, 2004 | 09:05 AM
SirHailstone's Avatar
SirHailstone
Some commuter!!!! Anyway - Jeff mentioned that apparently 3rd party brake controllers won't work on the new SD's. So if you're going to get it, go ahead and get the built in brake controller.
Old Nov 6, 2004 | 09:18 AM
tpetty's Avatar
tpetty
Yeah,
It's certainly more than I really need as my daily driver. I'm selling my BMW because I want to go back to a truck (more room, simply more comfortable for me) I want a big cab so I can bring the whole family when needed. Although it's not a "work truck" I do use the bed every week (firewood, brush, Home Depot runs, etc.) -- and I don't like the F150 only having a 5.5 foot bed. I had almost convinced myself to go ahead and accept the 5.5 bed -- but now I've been reading a lot of grumbling about the 5.4 V8 being underpowered and nowhere close to the advertised 300hp. I'm still not 100% sure, but am leaning toward the 250.
Old Nov 6, 2004 | 09:30 AM
Tell3131's Avatar
Tell3131
Since diesel gas is usually about 30 cents more a gallon than regular unleaded, you might want to calculate out the extra cost of gas vs the better gas mileage. I did something like this and I would have to own the truck for 31 years to make up the extra cost of the diesel engine. I factored in the better gas mileage for the diesel, but that isn't such a selling point anymore since the gas is so much more than unleaded. Unless you truly need a diesel to pull equipment, then the argument for the better gas mileage doesn't hold up too well anymore. Just my 2 cents.
Old Nov 6, 2004 | 09:34 AM
1956MarkII's Avatar
1956MarkII
We will not order a Super-Duty for stock WITHOUT the TowCommand package at this point. For what it costs, I can virtually guarantee a 100% return on investment at resale time.
Old Nov 6, 2004 | 11:14 AM
tpetty's Avatar
tpetty
Thanks Jeff, that's what I wanted to know. Figured it would be a desired option in the future.
Old Nov 6, 2004 | 02:02 PM
SirHailstone
What gets me is why Ford just doesn't make that kind of thing standard? I can understand a cut-away or bedless SD chassis (delivery, tow truck etc.) but that should be a standard item if anything because there's no provision to go back and add it later. Or is there?
Old Nov 6, 2004 | 06:34 PM
Polaris800's Avatar
Polaris800
Diesel is 10-20 cents a gallon cheaper than 87 octane gasoline where I live so it just adds to the advantages of a diesel.
Old Nov 6, 2004 | 07:30 PM
Tell3131's Avatar
Tell3131
Just wait, it won't be for long. Thanks to the government and refinement quality control.
Old Nov 6, 2004 | 07:50 PM
68 351 bronc's Avatar
68 351 bronc
The question was could the tow command be a dealer added option?
And at what cost vs factory installed?
Old Nov 6, 2004 | 08:01 PM
tpetty's Avatar
tpetty
In another thread, someone had already checked into this - and it cannot be added later, for any price. Seems kind of strange, but must be a hardware/computer difference with this option/of lack of, that doesn't allow later change.
Old Nov 7, 2004 | 02:39 PM
bgrover's Avatar
bgrover
It can't be added later because it is intergrated into the brake system to sense the brake pressure being applied. It is also intergrated into the ABS system to sense wheel lockup and adjust the system. All of this intergration can not be installed outside of the factory.
For more info do a search in the Superduty thread it has been discussed several times there.
