Can anyone tell me how to remove the black plastic bed caps off of the bed of a 04 f-150 screw... i know they pull loose on the side near the inside of the bed but they still seem to be connected on the outside. I don't want to pull to hard and crack the plastic so i decided to post the question to see if i can get some insight from someone who has taken theres off before... (reason is for the install of Putco Boss locker rails) JMW
I was wondering the same thing. Also, what is best to replace them with,
I was wondering the same thing. Also, what is best to replace them with, and what it looks like under them, also wondering if I should have LineX spray over the edge a little instead of using bed caps as I plan to get a Roll Top Cover for it eventually.
I cannot believe they didnt put removable plugs in so that you could put tie downs in. That really blows!
I would like to eventually put Tie Downs in the stake pockets, or bed rails, not sure which. And I am going to get a Line X Spray in, wasnt sure if I should take it over the edge or get some new bedcaps.
Either way, within the next six months I am thinking about installing a Retrax Roll Top bed cover. www.RollTopCover.com i think....
I didnt care much for the way this and other roll top covers sit on the plastic bed rails.
I just cannot decide which is the best way to go. I suppose those bedrails create a lot of holes to patch before you could spray line x over them, which is yet another issue..
