exaust
Old Nov 5, 2004 | 10:06 AM
tolie77's Avatar
tolie77
exaust
i want to install 4 inch exaust is it better to run 4" from turbo or go with 3" down pipe then 4" rest the way its on a 02 psd
Old Nov 5, 2004 | 10:35 AM
Kwikkordead's Avatar
Kwikkordead
Depends on what you want to do. If you want to make some big HP, some of the programs state very clearly 4" downpipe required.
Personally I would go with as big as you can afford. All it's going to do is lower your EGT's that much more. And sound really cool to boot.
Old Nov 5, 2004 | 05:37 PM
CAT_man_963's Avatar
CAT_man_963
IMO - there's not much sense in putting 4" back from the stock 3" downpipe - the downpipe is still your restriction point, unless you're never gonna use a chip or tuner - then you'd be OK. Otherwise - get a 3.5" or 4" downpipe with your exhaust - that way it's done all at once. I would imagine it would be a big pain in the rear to try to add just a downpipe later on.
Old Nov 7, 2004 | 03:35 PM
tolie77's Avatar
tolie77
Thanks for the reply i will go 4" all the way
