Brake -caliper piston seals
mopar and it worked good, on this one I compressed the piston couple of times and while daily driving kept it going ,not so much driving now so previously I got a new piston, pins, rotor, and pads, but couldnot get the piston seal and boot.
Any idea where to get the piston seal and boot, without the whole calpier.
Oh and spical note or problems in bleeding, I could not get my rear wheel celinder to bleed, so jamed a coat hanger in the bleeder hole and cleared the passage black gunk, works fine now!
I know it would be better to overhall $$$$$ is always a problem
But on the left side rear break I snaped off the bleeder,realy jamed up in the hole.
So I ask now, can I just purchas the rear wheel cylinder seperatly and where ?
Or must I get a kik and can the sides be swopped L\R, or should I just go get a junk cylinder?
Thanks
Jerry ranger
