Sponsored by: Auxito
possible fix to coil problems
Old Nov 4, 2004 | 02:59 PM
huntforfunnfood's Avatar
huntforfunnfood
with my 2001 f150 5.4 i have had plenty of the cop problems that many of you all have experienced as well. Most of mine seem to be from moisture getting in around the boot. here is my question as any one ever tried to use silcone or gasket glue around the block and the boot to keep moisture out? I know it would have to be a high temp type but why wouldn't this work other than being a miss if you go to change plugs???
Old Nov 4, 2004 | 04:35 PM
hugepettyfan's Avatar
hugepettyfan
Use the specified dielectric grease instead... On my #4 and #1 COPs, I greased them up good and no problems since... Helps the boot to release from the plug and head too. During the later plug change I did the other 6.
