1978 - 1996 Big Bronco
Tail light sockets
Old Nov 4, 2004 | 02:59 AM
Eagle9's Avatar
Eagle9
Question Tail light sockets
is the f 150 tail light sockets the same as the bronco because i need to splice some new ones in because my tailpipe had a loose clamp and it twisted up so the hot exhaust went into the body and along the wires and melted the insulation and the sockets and the rear of the tail light lens ( i already had some spare lenses) just need to know some option when i am looking for the hew parts?
also i am planing on putting a 6 inch lift on and with 35 and there i do a bit of highway driving what would be the best gear ratio i was thinking around a 3.89 would this really screw with my torque curve I have a 302 bored 40 over with a rv cam?
Old Nov 4, 2004 | 12:33 PM
greystreak92's Avatar
greystreak92
Yes the sockets and lens assemblies should be identical.
The gearing sounds a bit high for the tires but not 100% certain considering the rebore and the cam.
Old Nov 4, 2004 | 01:00 PM
Eagle9's Avatar
Eagle9
thanks for the help
Old Nov 5, 2004 | 12:45 AM
justshootme84's Avatar
justshootme84
4.56:1 gears are recommended for the stock 302's powerband, so I think 3.73 or 3.89 would still be a tad underpowered in your case. Do you know the actual Hp of your motor, or at least have an estimate? You should be able to go the math with one of the many formulas from there.
Old Nov 5, 2004 | 01:38 AM
kameronth's Avatar
kameronth
I have 31 inch tires with 4:10 gears and can still cruise 85 in my truck with no problem(in OD). I would go with 4:10's or 4:56's on 35 inch tires.
