holley 4160
Old Nov 4, 2004 | 01:18 AM
ford390gashog's Avatar
ford390gashog
holley 4160
there is a vacuum hookup coming of the metering block above the mixture screw and one at the bas next to the accelerator pump what are these for and how do vacuum secondaries work
Old Nov 4, 2004 | 08:13 AM
LxMan1's Avatar
LxMan1
That is ported vacuum for the vacuum advance on the dizzy. The secondaries work off of internal vacuum thru the primary barrels. When enough air is drawn theu the primaries, it will pull the secondaries open.
