Weird click noise
Old Nov 3, 2004 | 06:17 PM
LAL426's Avatar
LAL426
Weird click noise
I have the 04 FX4 which is about 3 months old. About 2 weeks ago I noticed a clicking type noise coming from the steering wheel area of my truck. It happened infrequently and could not be heard unless the radio was off (so, it is not all that loud). It now happens much more frequently when I am driving. It does not sound when going over a bump or rough road. It just makes a click noise every few seconds. Almost sounds like something is loose. Anyone have a similar issue or have any idea what it could be? Thanks
Old Nov 3, 2004 | 06:37 PM
WhiteNight's Avatar
WhiteNight
My guess would be the air conditioner compressor.No need to worry.
Old Nov 3, 2004 | 07:34 PM
kamikaze2b's Avatar
kamikaze2b
I had the same noise. Read this thread, that should answer all your questions.
https://www.ford-trucks.com/forums/s...d.php?t=292735
Old Nov 3, 2004 | 09:33 PM
Dunk's Avatar
Dunk
Have you checked to see if the wheel lug nuts are tight?
Old Nov 4, 2004 | 05:54 AM
LAL426's Avatar
LAL426
it is definately coming from the steering wheel area of the truck and not outside the truck like the wheel lug nuts
Old Nov 4, 2004 | 12:16 PM
kamikaze2b's Avatar
kamikaze2b
Did you read the thread?
Old Nov 4, 2004 | 12:39 PM
LAL426's Avatar
LAL426
I read the thread, but where is the fire wall?
Old Nov 4, 2004 | 01:00 PM
kamikaze2b's Avatar
kamikaze2b
The firewall is generally the section of insualtion/padding between your feet and the engine compartment.
Old Nov 4, 2004 | 01:35 PM
Dunk's Avatar
Dunk
I'd still check the lug nuts. Those alum wheels won't live long if they are loose. You'd be surprized how sound can travel and fool you from where it's coming from.
Old Nov 4, 2004 | 01:36 PM
BlueFX4Flare's Avatar
BlueFX4Flare
I have a clicking noise coming from my seat. It always happens on acceleration and turning. When my weight shifts to the seat back it makes a clicking sound.
Anyone else have this problem?
Old Nov 4, 2004 | 04:45 PM
seppypom's Avatar
seppypom
I had a rattle inthe center of my Dash, Below the Climate Controls, but then i took the change out if the ashtray and it went away!
