Dual mass flywheel vs. solid flywheel
Old Nov 3, 2004 | 03:34 PM
ROKRAWL's Avatar
ROKRAWL
What are the advantages and disadvantages of both? This is for a 97 350 diesel. is there a big difference in price?
Old Nov 3, 2004 | 06:33 PM
barebackjake's Avatar
barebackjake
the dual mass flywheel was built to absorb some of the diesel vibrations which are harder on the transmissions. it also makes the transmission seem quieter
problems dont last as long, cant resurface them, they wear with the clutch so they get bad, as the clutch gets bad. causing chatter, vibration, slipping bla bla.....and there $1000
single mass can be reused no moving parts to go bad, get higher clamp load,
but with single mass you can hear the tranny more and transfers some more vibration to the rest of the powertrain. but luk clutch packs have been engineered to absorb some of that vibration.
amsoil synthetic atf works great in theese trannys also
the whole conversion kit for the luk is about $600
ive got a luk in 2 trucks and wont ever put anything else in
Old Nov 3, 2004 | 09:26 PM
super440's Avatar
super440
We put a luk single mass conversition into my cousins truck. Works great and was alot cheaper than stock. Only the throwout bearing that comes with it isnt very good.
Old Nov 4, 2004 | 04:11 PM
RubberDuck's Avatar
RubberDuck
Super 440, Did your throwout bearing squeel after install too? Mine did, is was totally unhappy about that.
RubberDuck
Old Nov 4, 2004 | 05:12 PM
super440's Avatar
super440
yeah it does, and not long after installing it either. should have tossed it and put in a ford one.
Old Nov 4, 2004 | 06:01 PM
cliffaz780's Avatar
cliffaz780
Talking
I did the conversion kit from Idaho trans on ebay and I am very pleased. No problems with any of the items in the kit. I think I paid somewhere around 500 for the flywheel, clutch and all other parts to do the transfer. I have not heard any whine or trans noises. Shifts are normal and I am very happy with the whole thing. I would not think twice about the kit... makes $$$$ "cents" to do it!!!
Old Nov 4, 2004 | 09:38 PM
ROKRAWL's Avatar
ROKRAWL
towing?
How does the luk kit respond to towing? does it hold up? wear fast? Thanks. Talk to you later.
BMF
Old Nov 4, 2004 | 10:35 PM
FORD352V8's Avatar
FORD352V8
So far my clutch is fine so far but if it starts to go then ill thorw in a Luk.
Old Nov 5, 2004 | 02:54 PM
RubberDuck's Avatar
RubberDuck
Rokrawl, I have had no towing issues at all. I haul off scrap metal for a friend using his dump trailer about twice a month and it's not uncommon for the trailer to weigh 12,000 loaded. I also pull my mud bogger on a gooseneck alot and no problems there. To anyone else I would just recomend getting a ford throwout bearing.
RubberDuck
