tanny fluid
Old Nov 3, 2004 | 01:57 PM
muscletruck7379's Avatar
muscletruck7379
tanny fluid
would the 5 speed in my 87 ranger take the auto fluid or regular gear oil(which is what the owners manual says)
Old Nov 3, 2004 | 03:47 PM
G2IC_Wraith's Avatar
G2IC_Wraith
It depends on which trans you have. The Mazda trans takes ATF, while the Mitsubishi trans takes gear oil. Look under the truck to see what unit you have. There is usually a label on the driver's side of the trans that has a code on it....
Mazda says something like E87A-FE and has a 1 piece housing
Mitsubishi says something like FM146 and has a detachable bell housing
Old Nov 4, 2004 | 01:30 PM
muscletruck7379
i think that i looked before and it was the mitsibushi trans, i'll check again, but if so it would just be the normal 80-90w?
Old Nov 4, 2004 | 03:20 PM
el conquistador's Avatar
el conquistador
thats correct
Old Nov 4, 2004 | 03:25 PM
G2IC_Wraith
Originally Posted by el conquistador
thats correct
What he said.
