When I turn my key on in my 95 stroker the wait to start light and the CEL light flash in sequence. Also with the flashing a relay in the Power distribution box is clicking. I have ckecked my valve cover harnesses and they are good. Could it be that my GPR has shorted out? What do the 4 wires on the GPR operate? I assume one big terminal is the power input but what are the other 3. One big and two little ones. I guess I need to trace these and see if they are shorted out somewhere.
My truck will not start with the starter. I have to pull it and it will run very rough and eventuall die off. It will only run about for about 40 seconds and die. What could be my problem. I am thinking that if I get the clicking relay and the flahing wait to start light to quit my truck will run. Thanks Jake
