Sponsored by: Real Truck
05 shakes
Old Nov 3, 2004 | 12:30 PM
1olddog2's Avatar
1olddog2
05 shakes
05 sd s/c 5.4 1200 miles i love the truck {3rd super duty}but the streering wheel shakes slight to a lil worst on most lil bumps or large ones . drive on smooth roads very good at all speeds its just seems to vibbates. has many 1 esles notice this????
Old Nov 3, 2004 | 01:29 PM
superv10's Avatar
superv10
I had it - went back to dealer (after running truck over weekend) - they checked the balance and 3 of the tires were out of balance from Ford - rebalanced and lower the tire pressure from 80 PSI to 65 PSI - problem now GONE!!!!
Old Nov 4, 2004 | 09:19 AM
1olddog2's Avatar
1olddog2
going to bring in on monday to replace molding on door ,hopefully they can take care this then
Old Nov 4, 2004 | 12:06 PM
thedarkarcher's Avatar
thedarkarcher
Good post. I have had mine for 2 weeks now and love it. My first diesel...Had a toyota t100 before so this is a big step up.
I will keep an eye on my tire pressure
Old Nov 4, 2004 | 05:08 PM
Sunshadow's Avatar
Sunshadow
Question What is a good tire presure?
I've read on quite a few posts that new trucks were delivered with 80 or so PSI from the factory/dealer. The door sticker on my 2005 F350 FX4 SRW reads front 65 / rear 75. The tires are stamped at 80 (probably for maximum capacity). Mine was delivered with 55 all around, and the ride for 1600 miles has been great, although I do have to correct the steering more than I did with my old '89 F350 flatbed dually. Am I going to prematurely wear them out? Most of my driving is empty. I do tow a 7500# boat, but it doesn't add much weight on the truck.
Wayne
Old Nov 4, 2004 | 08:57 PM
beetlebarn's Avatar
beetlebarn
Shake
F250 KR SB 6.0 - my tires also had 55 PSi all around. Pumped up to 65 per the door, then de-aired to 60. Had the tires balanced by dealer and then by a shop that had a new machine. Ride improved after second balancing and setting tire pressure to 60. Still get a shake at around 45 and 75. From my experience with other steel belted tires that went bad, I think there is some belt movement, but it is just not consistent with the shakes to go back to the dealer. But love the handling and new turning radius and the ride is great too unless your at the magic speed. I have read a few post where the carrier bearing was replaced or reshimed. Not sure if I have this issue, but I guess time will tell.
Old Nov 4, 2004 | 10:14 PM
mikesZ06's Avatar
mikesZ06
I test drove a 05 sc 4x4 the truck ran smooth but the steering wheel giggled around alot when hitting minor bumps. Is this normal to the new 05's?
Old Nov 4, 2004 | 10:20 PM
superv10's Avatar
superv10
Don't think so - my CC doesn't do any of the shimying anymore after tires were balanced - ride is awesome!!!
Old Nov 4, 2004 | 10:44 PM
arcturner's Avatar
arcturner
Some were having problems with the Conti tires on the '05s for the first 500 miles or so. A few have hypothesized that these tires in particular seem to get out of round if sitting for too long and take a while to become round again.
Old Nov 4, 2004 | 10:54 PM
beetlebarn's Avatar
beetlebarn
Bump Steer and Contrac Tires
Steering Wheel wiggle or bump steer is part of the package with the 05's. It just happens on different road conditions than the left springers. I can go over the nastiest RR track and everything is great, but hit a dropped expansion joint over a bridge and you will need to hold on. I am hoping an aftermarket sterring stabilizer will come out to fix it.
As far as the Contrac tires, I have 2,200 miles on my truck and they still do not act right - guess I will just have to wear them out quick - unless I have a visible defect in the tire, the dealer was not willing to say they were defective. More miles will tell the story, but they are balanced as good as you can get them - wish Centramatic had their 05 balancers out - these worked great on my 02.
Scr3mn
New Member Introductions
May 3, 2013 05:43 PM
Scr3mn
May 3, 2013 12:52 PM
Lil Red Sled
24
Feb 28, 2011 12:47 AM
pakman5
Jun 21, 2009 07:59 AM
sand1
Feb 16, 2008 11:45 AM
