6.0 fix for various running problems...Must Read!
  #76
Old 10-04-2009, 04:26 PM
bismic's Avatar
bismic
bismic is online now
Received 2,513 Likes on 1,747 Posts
It is on your FICM - silver box on the drivers side - back towards the firewall.
  #77
Old 10-04-2009, 04:36 PM
4004 F350 dually's Avatar
4004 F350 dually
4004 F350 dually is offline
Under the hood or under the dash?
  #78
Old 10-04-2009, 05:19 PM
bismic's Avatar
bismic
Under the hood. Also the date is day/month/year (not the way we are used to seeing it - ie mo/day/year).
  #79
Old 11-04-2009, 07:25 AM
king of bass's Avatar
king of bass
king of bass is offline
Need Help 04 f-250
Thank for anyone that can help. Its a 6.0 it is very hard to start in the morning alot of black smoke takes about 20 min. to get it to start but after it warms up it cranks up fine.and I took it to the dealer and they told me it was the maf sen. replace it but it stills do the same thing but the tech said it threw codes po113,po0261,po267,po264,po270,po611,po273,po279,p o276,po282 then ran pin point and found maf sen. circuit open and what is a ficm thanks.
  #80
Old 11-04-2009, 07:38 AM
bismic's Avatar
bismic
FICM - Fuel Injection Control Module.
For the 7.3 guys it is the 6.0L version of the IDM.
The help you need is most likely a new FICM. Do not buy one off of Ebay. You get them at the dealership (some folks have talked International into selling them one).
There is a diesel place that says they can repair FICM's for less than half price of a remanufactured one (there are no more new ones). The name is SWAMPS.
  #81
Old 11-04-2009, 07:42 AM
moebdick's Avatar
moebdick
moebdick is offline
That's a lot of codes. Most are injector issues. I'm surprised it runs right. You may have an FICM harness problem.
  #82
Old 11-04-2009, 09:32 AM
king of bass
do you know were the ficm is found at? and thanks for all the help guys. on the truck sorry
  #83
Old 11-04-2009, 10:24 AM
moebdick's Avatar
moebdick
moebdick is offline
Driver side, under degas tank. It's about an 8" x 12" aluminum box with a sticker on it.
  #84
Old 11-05-2009, 11:36 AM
king of bass
its not under the hood under the over flow
  #85
Old 11-05-2009, 12:00 PM
moebdick's Avatar
moebdick
moebdick is offline
  #86
Old 11-05-2009, 12:53 PM
king of bass
Hey thanks alot guys you all have been alot of help.
  #87
Old 11-05-2009, 01:06 PM
king of bass
I'm taking it to the dealer on monday to get the FICM because they told me it had to be program. does that sound right
  #88
Old 11-05-2009, 01:25 PM
moebdick's Avatar
moebdick
moebdick is offline
Yes, when you replace the FICM the new one has to be programmed.
You did check the FICM wiring harness, right?
  #89
Old 11-05-2009, 01:30 PM
king of bass
no should I check that too
  #90
Old 11-05-2009, 01:55 PM
moebdick's Avatar
moebdick
moebdick is offline
There was a recall on some '04 models due to FICM wiring harness chafing issues. If your truck has not had Recall 05S34, read this to see if yours might have been affected:
Quick Reply: 6.0 fix for various running problems...Must Read!
