Is it a IDI or DIT?
Old Nov 3, 2004 | 09:43 AM
yodelking99143's Avatar
yodelking99143
Is it a IDI or DIT?
My recently purchased '94 F350 was manufactured in 3/94. The turbo cover says "Direct Injection". I was under the impression that factory DIT's weren't produced until after mid 94 and that anything produced in early 94 was a IDI. What's the deal?
Thanks in advance for any input.
Yodelking
Old Nov 3, 2004 | 10:35 AM
pnose's Avatar
pnose
If you can see the injectors its an idi,if you cant,its a powerstroke.
Old Nov 3, 2004 | 03:04 PM
Kenworth's Avatar
Kenworth
Does the truck have a 5spd behind it ?
If so its most likely a DI as the first PSDs only came with a 5spd in 94.
The biggest give away is if the fuel filter is under a black cover its a DI the IDI turbo had a spin on filter on a bracket behind the Alt.
Old Nov 3, 2004 | 03:43 PM
yodelking99143
Yes, it is a 5 spd. And it does have the fule filter under a black cover. So... it looks like they started putting in DITs in March of 94.
Thanks for the info.
