Aerostar Ford Aerostar
transmission rebuild
Old Nov 2, 2004 | 04:28 PM
t0ny78's Avatar
t0ny78
i think i gona attempt a rebuild on the trans in my star my self. any body do this befor? what will i need? any advice and pointers will be appriciated thanks.
Old Nov 2, 2004 | 05:18 PM
SgtJoe's Avatar
SgtJoe
Depending on your mechanical skills, transmission rebuilding is not the hardest task out there.
Start with a good book (not a Chilton or Haynes). Get the Ford service manual if you can.
If your trans is an A4LD, then replace the governor ($25-$30). Worth it....trust me.
When you put the center support in, stand the transmission upright so the seals don't hang down and get sliced.......trust me.
DO ONLY ONE VALVE IN THE VALVE BODY AT A TIME......trust me, really, trust me.
If you fill the transmission while the front end is jacked up, don't freak out when fluid pours out of the top. The fluid will escape out of the vent hole. Lower the vehicle and keep going.
I can give more tips, so please ask more questions when you start. I will be more than willing to help you out. Good luck and dive in!
Old Nov 2, 2004 | 08:31 PM
t0ny78's Avatar
t0ny78
thanks for the courage. i like to think my mechanical skills are pretty good. iam gona find me a book on the trans and read into it then i will atempt it hey theres a first time for everything. i will keep ya posted. thanks
Old Nov 3, 2004 | 01:00 AM
JTHill24's Avatar
JTHill24
t0ny78:
I rebuilt two A4LDs for less than $300.00 each & they have been running great.
The place for parts is www.bulkpart.com
Then I went down to NAPA and got a A4LD techtran manual.
From ATSG (automatic transmission service group)
These are the parts I bought for mine. I rebuilt 2 of them.
The only difference in the 2 - same year 89 was that one had a different size Servo Piston then the other.
1= 23017B Banner Kit 85-89
2= 23997 Flex Bands Intermediate & Overdrive
1= 23853 O/D Planetary
1= 23880 Overdrive Sprag 85-91
1= ***** Intermediate Servo Piston
1= ***** Overdrive Servo Piston
1= 23901 Modulator no stripe
1= 23922A Filter 2WD 89-up
I got these with $7.50 shipping for a total of $214.88
1= ATSG FORD A4LD Techtran Manual Picked up from NAPA.
Jay
Old Nov 3, 2004 | 03:29 PM
jkorreck's Avatar
jkorreck
Hey JTHill were there any special tools you had to use? I thought I remembered hearing that you had to have a few for the A4LD.
Old Nov 3, 2004 | 04:39 PM
M.Herrington's Avatar
M.Herrington
yanno, after seeing all of jthill's posts, i think i might be taking a drive out to his house one day, lol
Old Nov 3, 2004 | 08:09 PM
JTHill24's Avatar
JTHill24
jkorreck:
As I remember the only special tool I needed was the Snap-Ring Pliers. I'm looking to see if I can find a junk A4LD that I can take apart and put back together. Then I can post them on the web site that M.Herrington was so kind to allow me to use.
M.Herrington:
Thanks Again.
Jay
dtgl90vt
Jun 21, 2016 06:29 PM
Florida cracker
Feb 20, 2015 08:07 AM
Jonesy0027
Jan 7, 2013 01:54 PM
dnmyoda
Apr 12, 2005 07:12 PM
canadianfordman
May 17, 2002 08:08 PM
