I need some help. I removed the hpop and cleaned out the ipr. I also installed new o-rings in it. Now the darn thing won't start!! Feul pressure is there but nothing. No smoke out stacks.I figure the injectors are not firing. I took my time and i know i put it back together right. What do i do!? I am very mechanically inclined so i'm not worried yet! Please help me if you can! Thanks in advance lance!!! P.S I'm gonna borrow my buddies scan tool and make sure the HPOP is making over 500 psi! Also the tack does move when rolling over so i'm assuming the cps is alright!
Make sure HPOP is full and then remember you're going to have air in the system now so it'll take a few cranks for it to fire up. Crank for 5 sec and rest the starter for 15 sec so you don't burn it up. Let us know...
Hey guys Lance here. Well i have some good news and some bad news. I don't know what happened but some how cleaning and replacing the o-rings ($50.00!!) somehow killed my regulator. It must have been stuck in a position that would build up pressure. After cleaning the sucker wouldn't build up more than 250 psi! Need atleast 500psi to fire injectors. Not sure how they work but my guess is the magnetic thingy around it was done. Soooo i go to my local Ford dealer. Good guys i must say. Price out a new ipr. $475.00!!! (cdn that is) but says i can have it for $375.00. Well lets say i walked out with a puckered butt So i came home and phoned the Intenational dealer. They were only $278.00. So off i go. An hour later and $318.00 shorter(damn taxes!) i have the magic part! Put it together and she fired up! So i ended up throwing out $50.00 worth of o-rings but what can ya do All that matters is it runs and no more check engine light. Thanks alot for the replies guys a have a great day!!!
