Hey All
I have two questions. First, does anyone know where I can get the rubber tube that goes from the fuel tank up to gas fill opening. I don't mean the plastic hose that actually goes into the tank for refueling. I put a 3 inch body lift on my'90 B2 and I pulled the rubber hose of the tank just enough where it leaks if I fill up. Also, my engine (2.9) has started a roaring sound when i get into her a little or going up hills on the road. I was told it was my fan and that i could also be losing compression.
I would appreciate any help or info.
that must be it then. I was planning to install an electric fan anyway. Thanks Ken.
Anyone know where I can get that rubber tube at? Someone I know suggested a boat supply store. Make sense?
