Sponsored by: Real Truck
03' 250 SD Fx4 steering drift
Old Nov 1, 2004 | 08:42 PM
Hawgin1's Avatar
Hawgin1
Just installed 4" lift and 325- 20's. I had a little drift
before. But now it's really magnified. I put dual stab.
on. I had the front end looked at. The tech said nothing
worn out, looked good and tight. He's thinking power
steering pump. Do 250's and 350's have the same pump. I tightened the steering box about 1 full round.
No results. This truck only has 26,000 miles. I need
help.
Old Nov 1, 2004 | 08:46 PM
DJR 17's Avatar
DJR 17
What do you mean by drift? Is there play in the steering wheel? Or is it pulling to one side?
Old Nov 1, 2004 | 09:26 PM
Hawgin1's Avatar
Hawgin1
What i mean is when your going down the road with
the steering wheel straight the truck wonders from
left to right. Kinda hunts the grooves in the road.
Old Nov 1, 2004 | 09:52 PM
DJR 17's Avatar
DJR 17
It might be in your tires. I had this problem with a brand new set of michelins. The tires may be flexing in the tread not the sidewall, in which case it should get better as you wear them down. You might try adjusting the tire pressures and see if it makes any difference.
Old Nov 1, 2004 | 10:02 PM
Hawgin1's Avatar
Hawgin1
I'll try adjusting the air pressure. Thanks
Old Nov 2, 2004 | 12:27 PM
Hoosierdaddy's Avatar
Hoosierdaddy
Could very well be the tires. I had the same problem with a new set of BFG's, Rotated the tires and everything was fine!
