cracked block asap answer thanx
Old Nov 1, 2004 | 05:14 PM
dr worm's Avatar
dr worm
Exclamation cracked block asap answer thanx
if your block is cracked will antifreeze leak out?if so will it drain the raidiator? i
Old Nov 1, 2004 | 10:26 PM
quadrazer's Avatar
quadrazer
Could leak antifreeze or oil, depending on where the crack is. If you have an antifreeze leak, I wouldn't jump to the conclusion your block is cracked unless you actually see a crack in the block. If you are leaking antifreeze, a radiator pressure test should reveal the source of the leak.
