4 barrel holley problems
Old Nov 1, 2004 | 07:34 AM
chromiumh1's Avatar
chromiumh1
A buddy of mine rebuilt his 4 barrel Holley carb. After it was done he bolted it on and it won't idle and has no throttle response. I don't know many more details he brought it up and i said i would post it for him. Any7 info would be greatly appreciated. Thanks in advance.
Old Nov 1, 2004 | 06:27 PM
lee's Avatar
lee
Hum,
Well, did he adjust the floats correctly? How about the idle mix screws? Also the choke?
Lee
Old Nov 2, 2004 | 10:30 AM
chromiumh1's Avatar
chromiumh1
Originally Posted by lee
Hum,
Lee
Well he has been at this stuff for a lot of years i just asumed that he would've checked all of that. But i will talk to him about it. Thank you for the input.
Old Nov 2, 2004 | 12:16 PM
big hoss 29's Avatar
big hoss 29
I rebuilt my Holley 3 weeks ago, and after I did, I had nothing but troubles. It was a Holley 4180 and now it's a dump decoration. It leaked fuel out of the accelerator pump, metering blocks, and fuel rail. I dumped it for an Edelbrock 1406 and I've never been happier with the performance.
Have your friend get an Edelbrock and dump the Holley, he'll be happier than ever.
Old Nov 10, 2004 | 08:10 PM
huskyhauler's Avatar
huskyhauler
holley 4180 was a bad carb from the get go. it was a disposable carb. it had a bad primary booster design that made it prone to freeze ups on cold mornings during decel, or any time the air temp was under 45' and vacuum hit 27-28" of mercury. as for all holleys being bad, i run a 80457 on my 514 f250 i regullary get 10+mpg. i had a 1406 on it, and never got over 6mpg. the tuning on the edelbrock-carter carbs is easy, but very limited. the secondaries have a poor metering design that real needed to be updated in the 70's. but holleys(4150-4160) have the same issues. they are a pain in the *** to get set up. but once it gets down right, nothing will blow the doors off like a holley. but its alot of work. in 8k miles, i have yet to get mine just right. still a bit rich, but the bogs are gone both empty and towing. if simplicity is what you like, go with an edelbrock. if you like to play, than get a holley.
Kurt
jonny.redneck
Apr 23, 2014 04:43 PM
The Truck Whisperer
Jul 2, 2012 11:42 AM
Kalve
13
Oct 11, 2010 09:52 AM
1985ColumbusF150
15
Nov 17, 2004 10:45 PM
TheGreatOne
Jun 2, 2003 11:59 PM
