Replacing Front Main Leaf
Old Oct 31, 2004 | 05:45 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
In the process of putting disk brakes on the front end I noticed I had a broken main leaf. The new reverse eye main leaves finally shipped. I found the front spring shackle kits at Sacramento Vintage for $40.00. Anybody orders these parts through a local shop such as Napa how was the price? Also I had a couple of shims between the front springs and the axle I assume they are for alignment. With the reverse eye springs and removing a few front springs should I just leave them out but keep them and see if the alignment shop needs to use them?
Old Oct 31, 2004 | 06:31 PM
Christopher2
Veteran: Navy
OK is there anything I should know when replacing the bushing in the frame mounts. I just read the manual and it does not say anything about the bushings.
