Predator and tire size question...
Old Oct 30, 2004 | 03:02 PM
Heckler's Avatar
Heckler
I realize this may be the wrong forum to post this but so many of you also run the predator I figure one of you would know.
If I install a Predator tune and I dont have stock tire size is there something I need to do? I did have my dealer recalibrate my truck for the tires I have (35's) does the Predator tune need to be adjusted as well?
<!-- / message -->
Old Oct 30, 2004 | 09:17 PM
smith- 04 6.0's Avatar
smith- 04 6.0
You're good...no tire size adjustment can be made in the Predator. The only adjustment the Predator will have to make is burning those 35's a split-second later than it would the stock tires!
Old Oct 30, 2004 | 09:49 PM
jdadamsjr's Avatar
jdadamsjr
And other than that...
the predator will recover the lost "snap" from putting the larger tires on...
that's why it's called the "predator grin"
Old Oct 30, 2004 | 10:33 PM
Heckler's Avatar
Heckler
So does that mean that my speedo will be off with the Predator tune? or will it pick up the calibration from the stock flash?? I guess I can get out my gps and check it.
thanks
