Burning oil
Old Sep 5, 2002 | 10:53 AM
sizln6's Avatar
sizln6
Burning oil
hi all
I have a 93 ford splash 4.0. It is burning oil and i cant see it leaking anywere. does any one have any suggestions? i dont know what to do?
Old Sep 5, 2002 | 11:44 AM
AOGDEN's Avatar
AOGDEN
Burning oil
[updated:LAST EDITED ON 05-Sep-02 AT 12:44 PM (EST)]As you are driving the truck does it smoke as you accelerate or decelerate ?? Smoking on acceleration is usually a sign of worn rings. If it smokes on deceleration look at the valve seals.
Old Sep 5, 2002 | 12:00 PM
sizln6's Avatar
sizln6
Burning oil
i can smell it burniiing after i shut it off if that helps any i will check to see when smoke comes out
Old Sep 6, 2002 | 07:47 AM
ZeeDee's Avatar
ZeeDee
Burning oil
If you can "smell the oil burning" and smoke is not poring from the exhaust, it sounds like you have a external oil leak. Most likely oil is leaking from either the valve covers, or the oil pan and dripping on the exhaust manifold or pipe. Open up the hood and look careful for wet spots. If everything is covered in grime and oil, go to a car wash and degrease/wash the engine. Then drive for a day or two and look again for wet areas.
Good luck
Old Sep 6, 2002 | 09:25 AM
propellerhead's Avatar
propellerhead
Burning oil
lordyfordy
3.8 & 4.2L V6
Apr 3, 2023 05:13 PM
rollinblackcloud
May 12, 2013 10:55 AM
TJC
25
Mar 3, 2008 10:17 AM
makthenif
3.8 & 4.2L V6
Jan 15, 2007 10:29 PM
